Hood not opening
Old Oct 7, 2018 | 10:19 PM
Lanerovermex's Avatar
Default Hood not opening
😭😕 Help in need of oil change !!
Old Oct 8, 2018 | 06:41 AM
Use a bungee cord/other person to hold the hood release handle open. Then go give a pull.
Once open clean the latches and lube them. If your in luck you will be good to go
Old Oct 8, 2018 | 09:04 PM
Blackngold77's Avatar
another way is take the front grill off and use pliers to pull the cable.
you can take the grill off with the hood closed with a flathead screwdriver and patience. use the screwdriver to get under the hood lip and push down each tab 1 at a time (pull the grill away when pushing down).
with enough trying and swearing you can get it.
also, once you get it open, odds are you need to put the cable connector back together (small black box on the outside wall under the hood. its prone to popping open, and when it does no hood opening. when its back together, wrap a couple zip ties around it so it doesnt open again
Old Oct 8, 2018 | 10:49 PM
Geo's Avatar
Geo
Sounds like a good preventative tip! I’ll try to remember to do that next time I’m in there.
greenharoguy
Feb 20, 2013 11:42 PM
Savannah Buzz
Nov 27, 2011 12:33 PM
workinghard1713
Nov 13, 2011 08:53 PM
bmxermike
Dec 31, 2010 12:57 AM
Disco Fuego
Feb 21, 2009 04:59 PM
