how to unclog sunroof drains
Old Dec 9, 2014 | 07:08 PM
TOM R's Avatar
Default how to unclog sunroof drains
pics courtesy of DanC
Old Dec 9, 2014 | 07:11 PM
TOM R's Avatar
you need this pump from harbor freight or some compressed air
Old Dec 9, 2014 | 07:14 PM
TOM R's Avatar
Size:  13.2 KBclogged drain at each corner
pump to unclog
Old Dec 9, 2014 | 07:16 PM
TOM R's Avatar
now if you unclogged it and pour water in those drains it should come out in front of the door on each side bottom of A pillar
Old Dec 9, 2014 | 07:19 PM
TOM R's Avatar
otherwise you may need to pull the drivers kick panel like so to access the drain where it goes through the body
Old Dec 9, 2014 | 07:24 PM
TOM R's Avatar
it will expose this rubber elbow / grommet be sure it is in place and not torn
to access the pass side follow the instructions to remove the fender vent it will expose this
Old Dec 9, 2014 | 07:28 PM
TOM R's Avatar
now if everything looks good and water comes in and or runs down the inside A pillar covers the drain tubes might have come off the sunroof or have a hole, either way this will require at least a partial drop of the headliner to access the underside of the sunroof
there are also rear drain tubes not pictured, they run down the C pillars from rear corners of sunroof
Old Jul 26, 2018 | 11:41 AM
TOM R's Avatar
Added info that might help with drains
https://landroverforums.com/forum/lr3-28/rear-sunroof-drain-locations-lr3-87195/
Street Wolf
Nov 13, 2011 05:02 PM
yloDiscoII
Jul 23, 2011 03:47 PM
Street Wolf
Jul 19, 2009 10:39 PM
Street Wolf
Apr 13, 2009 06:43 AM
Street Wolf
Mar 31, 2009 05:16 PM
