Injector cleaning wisdom needed
Old Nov 11, 2019 | 05:59 PM
Land Over's Avatar
Default Injector cleaning wisdom needed
2006 128k on the clock. Decided to do an injector cleaning last weekend. OTC canister, BG cleaning solution. Ran the canister dry and let the Rover stall. Pressure was 58, 60 psi. Flooded the engine so bad that it took no less than 6 WOT (pedal to the floor) cycles to get her cranking back up. Question. Is it normal for it to flood so bad? My understanding is the pressure on the injectors is 65 psi, so if anything I was giving it less than what it normally runs at.
Old Nov 12, 2019 | 09:54 AM
Land Over's Avatar
I guess I'll ask it this way. When some of you guys performed this type of cleaning, did you experience what I did? I read some of the threads and all of them mention some degree of flooding. I just never thought it would be so pronounced. I remember doing this on my old Ford back a few years ago and it had fired right up.... I know, 5.0 Windsor isn't the 4.4 Jaguar...
Old Nov 12, 2019 | 01:21 PM
User's Avatar
I've had luck with simply pouring BG44K into a half tank of fuel every other month instead of running it through the intake/vacuum system.
My MINI cooper however being direct injected I ran through the intake, and I had to keep the RPMs at 2500 and spray in short bursts so it wouldn't stall.
Old Nov 12, 2019 | 02:04 PM
abran's Avatar
Never had one flood. I put the Fuel Pump relay back in, cycle the ignition to Pos 2 twice and fire right up.
Old Nov 12, 2019 | 02:13 PM
Land Over's Avatar
Interesting. What Rover magic happens when you cycle the key to position II twice?
Old Nov 12, 2019 | 04:34 PM
Cycles the fuel pump twice would be my guess
Old Nov 13, 2019 | 09:32 AM
Land Over's Avatar
Ah, of course... Fills the empty fuel line, delivers the gasoline to the rails.
Another observation. There is a video on YouTube of Storey Wilson (of the RSW Solutions fame) performing the cleaning and he mentions that he gave it 35, 40 psi. Basically half of the pressure the rails normally see. As far as I can tell he had no problem afterwards... Anyway, it is academic at this point. Just curious and thought someone might use this info in their case.
Thank you guys. Glad we have this forum to share ideas and insights.
Old Nov 13, 2019 | 02:31 PM
abran's Avatar
Good guess.
Omorin34
Jan 31, 2016 12:38 PM
vsop4me
Nov 8, 2015 10:35 AM
willrok13
Oct 31, 2013 03:31 PM
wildlifeguy
Feb 10, 2011 12:48 PM
FightOnUSC79
Oct 28, 2010 11:45 AM
