Just bought a 06 LR3 - need advice staying on top of maintence
#21
Can't thank you guys enough. Really solid advice.
The only obvious issue I'm noticing at the moment are the front brakes which I'm doing this weekend. Also sounds like the consensus on these boards is to swap out the tranny fluid even though every shop I talk to says to leave that pandoras box alone.
My fear around the tranny is probably fueling the urge to buy the extended warranty. If I do I'll be reading each word of fine print.
#22
Despite not having touched the L3 tranny yet, I HAVE changed all the fluid on my L322 a few weeks ago and have noticed no ill effects. I haven't really noticed any improvements either, but that tranny shifted smooth as butta to begin with. The reason I changed out all the fluid was due to a tranny overheat issue, so replaced the oil cooler, fluid, and filter (radiator had just replaced recently).
rmally
04-22-2008 12:26 AM
