Just changed the oil in the LR3! 4.0
Old Feb 17, 2009 | 05:15 PM
eshew's Avatar
Default Just changed the oil in the LR3! 4.0
So changed the oil in the LR3 today!
Easy, it required 6 quarts of Castrol 5-30. Got a deal on it a Schucks, Checkers or whatever its named around you. $3 a quart.
Got a WIX filter at NAPA because its the only filter I trust, Fram and Quakerstate and others are pretty crappy filters, wont use em even of they are free.
Took out my trusty plastic ramps and got the front end up on em.
13mm socket to take off the 10-12 bolts for the skid plate, all self explanatory and easily removed and replaced by 1 person. If you have any rocks chillin in the skid plate clean it off as they could get in the way when tightening down the bolts after the oil change.
The oil pan plug was a 13mm too, very nice
The oil pan did leak down on the A arm a bit so if you have a pretty garage and want to keep spot free it might be good to toss down some card board.
Oil filter is mounted vertically and came off relatively easy, had to get my arm in there for some leverage but off she came. It did leak a bit when it came loose onto the A arm and frame so have that cardboard placed before hand.
Tossed on the new WIX filter (after pouring 1/3 quart into the filter to reduce dry start), poured in 6 quarts of Castrol GTX, placed the skid plate up hand tightening all bolts before getten em tight with the socket wrench.
DONE!
Old Feb 19, 2009 | 01:11 AM
LRthree's Avatar
Nice write-up! I am planning to get an LR3 in the near future, and plan to do all the maintenance works myself.
cipher982
Nov 30, 2011 09:12 AM
04discomw
Jul 23, 2010 09:27 AM
Spencerfitch
May 31, 2010 12:26 AM
Memphy03
Aug 3, 2009 08:58 AM
02lrfreelander
Freelander
Mar 9, 2009 06:50 PM
