Just ordered new coolant hoses...
I ordered a bunch of coolant hoses from Merriam Parts (Better prices than Atlantic British) to fix some small leaks, and a coolant reservoir to eliminate the low coolant message. I am replacing thermostat housing and primary/secondary belts while I'm there.
I was curious if anyone had any tips/time saving advice or things to be cautious of during this epic endeavor?
I am looking forward to finally turning a few wrenches on the beast!
The following 2 users liked this post by Airstream345:
AtlantaViking (09-16-2015),
DieHard (09-28-2015)
Expansion tank, multiple hoses, water pump, thermostat housing, belts, coolant flush, all went without much of a problem. The biggest issue was getting the throttle body off to reach the top torx bolts of the thermo housing that were burried under it. That was an unexpected adventure in itself, but not awful.
The labor intensive part of the job took me about 5 hours, which is about what I was expecting. Then had to bleed the system.... Start the engine, let it warm up, open bleed screw on expansion tank, turn the engine off, close the bleed screw, let the engine cool down, add coolant, and repeat 4 or 5 times.That process took much longer than I was expecting (close to 2 hours).
All in all, I spent close to $300 and an afternoon of my time in the garage. Probably saved 3X that considering labor at a LR dealer.
Thanks again for the tips gents.
lipadj46
09-04-2009 09:52 PM
Disco Alan
07-14-2006 01:28 PM
