Just ordered new coolant hoses...
Old Sep 15, 2015 | 01:56 AM
DieHard's Avatar
Default Just ordered new coolant hoses...
I ordered a bunch of coolant hoses from Merriam Parts (Better prices than Atlantic British) to fix some small leaks, and a coolant reservoir to eliminate the low coolant message. I am replacing thermostat housing and primary/secondary belts while I'm there.
I was curious if anyone had any tips/time saving advice or things to be cautious of during this epic endeavor?
I am looking forward to finally turning a few wrenches on the beast!
Old Sep 15, 2015 | 08:24 AM
AtlantaViking's Avatar
Nice Coincidence. I just got my recovery tank yesterday and I'm waiting on the thermostat housing now. I'll keep my eyes on your thread to see if anyone posts up some good advice!
Old Sep 15, 2015 | 04:23 PM
Airstream345's Avatar
Get/rent the fan wrenches from AutoZone ($25). I've used mine far more than I planned when I did my first job that started with "remove the fan".
Various extensions and "wobble" sockets help a lot with the thermostat housing replacement.
It's a perfect time to replace the water pump too.
Old Sep 16, 2015 | 04:33 AM
DieHard's Avatar
Thanks for the info gents!
I am going to add the water pump to the list as well, it's going to be one hell of a day in the garage! Any ideas on what brand WP to buy? Any experience here?
Old Sep 18, 2015 | 04:21 PM
unseenone's Avatar
Get it from the same place- OEM. Do not skimp here.. just did mine, also all the hoses at the same time. Ordered from the same place as well.
I did end up duplicating one part somehow.. Probably because I did two separate orders.
Old Sep 18, 2015 | 06:04 PM
DieHard's Avatar
I ordered the water pump from Atlantic British. They say it's good quality so I've got my fingers crossed.
Still waiting on a couple parts to arrive so it looks like next weekend is the weekend.
Old Sep 28, 2015 | 01:06 AM
DieHard's Avatar
Default Job well done.
Expansion tank, multiple hoses, water pump, thermostat housing, belts, coolant flush, all went without much of a problem. The biggest issue was getting the throttle body off to reach the top torx bolts of the thermo housing that were burried under it. That was an unexpected adventure in itself, but not awful.
The labor intensive part of the job took me about 5 hours, which is about what I was expecting. Then had to bleed the system.... Start the engine, let it warm up, open bleed screw on expansion tank, turn the engine off, close the bleed screw, let the engine cool down, add coolant, and repeat 4 or 5 times.That process took much longer than I was expecting (close to 2 hours).
All in all, I spent close to $300 and an afternoon of my time in the garage. Probably saved 3X that considering labor at a LR dealer.
Thanks again for the tips gents.
calebbo
Jul 31, 2011 12:19 AM
Danny Lee 97 Disco
Mar 4, 2011 12:28 PM
lipadj46
Aug 4, 2009 06:06 AM
Disco Alan
Jul 14, 2006 01:28 PM
