Key fob buttons suddenly stopped working, can't find splice
Old Mar 4, 2026 | 12:08 AM
Tristan Stumpf's Avatar
Default Key fob buttons suddenly stopped working, can't find splice
Hello all,
My key fob buttons suddenly stopped working on both remotes I have. Key still starts the truck just fine.
I tried reprogramming the remotes with no success. I figured it must be the splice in the wiring loom found under the kickplate of the right front (passenger) side.
U pulled up all the plastic bits bit for the life of me I just can't find the splice.
What am I doing wrong here? Does anyone know about where the splice should be? I attached a photo of where I was digging.
Edit:
I attached a wire trace machine and put it on fuse 43 as many suggested, I could not find the wire splice, I pulled f
Door sills on both sides looking for it with no luck. Can someone help me with a wiring diagram? I don't know what to check next.
Old Mar 13, 2026 | 09:18 AM
ZLanduyt's Avatar
4th Gear
Power wire to the antenna runs through the left side A pillar then across to the middle of the headliner right behind the first sunroof. I had the same issue and found no power at the antenna. I ran a wire overlay and powered it with fused battery power. Good luck!
Old Mar 23, 2026 | 05:49 PM
The_OGCJR's Avatar
its in there...I've repaired mine and it still didn't fix my issue. But anyway, just so you know, its a splice with four wires on my 2007 (not 3) and all the wires are green with a white stripe even though the wiring diagram says different.
Those green and white twisted wires in your pic are your speaker wires. It is not that.
KEN189
Freelander
Sep 12, 2024 09:37 AM
Yosoymilk
May 24, 2022 12:00 PM
DoubleAFL
Sep 14, 2019 11:34 PM
mpattong
Aug 16, 2017 09:38 PM
Aru
Jun 28, 2014 12:19 PM
