Land rover LR3 Red suspension Fault issue
Old Sep 28, 2023 | 04:34 PM
vito13's Avatar
Default Land rover LR3 Red suspension Fault issue
Been battling with this car for awhile.
after dealing with non start issue, ended up being corroded wires on grey plug under the dashboard due sun roof drain pipe leak.
now after taking apart front end suspension to replace front upper and lower control arms I got this suspension Fault.
Codes I'm getting, always coming back after clear are:
- C1A00-88 control module
- C1A00-54 control module
Apparently something to do with vehicle dynamics control module or abs and ride control module.
I manege to clear some faults and suspension raised, compressor start working.
Sometimes transmission fault and DSC fault comes on too.
Any one with similar situation as well?
Old Sep 29, 2023 | 02:07 AM
kajtzu's Avatar
With the grey plug do you mean the brake light switch under the steering wheel? Did you replace it or fix it in situ somehow? If the switch itself is faulty it’ll give you a ton of cool and simultaneously horrifying errors.
Anyway, for the suspension issue - you might want to recalibrate the suspension. A guided calibration be done with an IIDtool, for example. It’s easy.
PaulT999
Nov 25, 2023 12:13 PM
jdubbayew
Aug 21, 2023 10:45 AM
edwardmoya
Oct 7, 2022 10:25 PM
deer40111
May 7, 2019 08:10 PM
