Suspension Fault
Old Aug 21, 2023 | 10:45 AM
jdubbayew's Avatar
Default Suspension Fault
The classic suspension fault thread...
- First start up throws "suspension fault" with code C1A00-49 (AF) Control module - System internal failure - internal electronic failure & U0132-87 (0B) Lost communication with ride level control module - Bus signal/message failure - missing a message
- Turn the car off and start it again and "suspension fault" goes away. Suspension works as normal
This is a 2006, so I will investigate the driver's wheel well wiring rub and grounds this week. As well the grounds in driver's footwell.
I also intermittently get
  • U0132-87 (0B) Lost communication with ride level control module - Bus signal/message failure - missing a message
    ( on 17-08-2023 19:24:47 at 104474 km )
Previous owner had the vehicle on a trickle charger, which was wired in very poorly to the battery. Appears to have fried the SRS(RCM) module as well.
nickinps
Feb 26, 2024 08:52 AM
PaulT999
Nov 25, 2023 12:13 PM
Wilybyrd
LR4
Mar 30, 2022 06:17 PM
nadatmo
Mar 17, 2022 06:16 PM
Captain Sygo
Oct 31, 2017 10:55 PM
