Largest spare tire underneath?
285 65 R18 would be out of the question. I am running a set of Nitto Trail Grapplers in that size (converts to 32.59 but advertised as 33in) and they are too big for the vehicle. I would concentrate on what fits in the wheel well first and then see if it fits in the spare location. Also, there are plastic "heat shield/beauty trim panels" that could be removed to aid in increasing available space. If the tire still does not fit, there is no real issue as the full size spare will decrease your departure angle and, if you are off roading, the best place for a spare is either the roof rack or the rear bumper.
you can see tire sizes converted to inch measure total diameter here:
LR3 Tire Size Chart
with that said now I am curious too. I am going to have a tire off in the near future, so I will try winching it up and update the thread with the result.
LR3 Tire Size Chart
too large and all four wheel wells fill up
My view is what limits the wheel size on a 3 is not the spare tire wheel well but the wheel wells themselves.
Guys have found that with much more than 32" OD, when the air system fails and the 3 drops, the wheels freeze in the wheel wells. Then the fun begins.
As to the limiting tyre size, well that depends upon how much frozen mud is already in the wheel wheels. In other words, the stock 30" OD can be too large.
Yet another reason for relocating the spare; it won't do you much good if you can't use it. I am not even running with a spare, my oversize tires and a stock spare would likely blow a diff if I ever put it on. I have yet to buy a repair kit and a compressor. Perhaps another member of this fabulous forum would be able to measure the clearances on a mounted spare and do a bit of math for you?
911turbo
09-14-2008 10:53 PM
