Left front speed sensor / wheel bearing now electical?
I had a code pop up saying left front speed sensor not reading.
I replaced it.
Next day the lights where back on and said left front again - then the wheel bearing imploded!!! Like bad! so I replaced it. And the light came on again:
replace the sensor again thinking maybe it was collateral damage to the bearing going… same issue same wheel.
any ideas?
gap iid shows no speed being read on that wheel either.
08 Lr3 4.4 hse
thanks in advance guys and gals!
I replaced it.
any ideas?
08 Lr3 4.4 hse
when it reads it’s right in step with the other wheels- not off or sporadic
also now it’s saying my transmission is overheating and slow down when I start the truck up
After checking again and poking around and running through the steps of install… no visible damage on the halfshaft or knuckle. Wires are clean and connector is good and clicks on the speed sensor. Wires going into the harness look in new condition. No knicks or anything.
Sprayed it all with air. Put it back together and no lights.,, until 1/2km up the road. Then they all came back.
could this be trans temp related as that’s now popping up?
all my lights are working and the gap iid shows my brake switch functioning
