Locking Differential Fluid
Old May 2, 2017 | 01:31 PM
djkronik57's Avatar
Default Locking Differential Fluid
Has anyone used Ravenol MDL for their rear locking differential fluid? It says it meets Land Rover LR019727 specifications and is less than half the price of the LR fluid (Castrol BOT 720).
Amazon Amazon
I have to say I'm not sure what a "clutch-type Lamella limited slip differential" is.
Old May 2, 2017 | 01:48 PM
houm_wa's Avatar
I wouldn't do it.
Old May 2, 2017 | 05:50 PM
EastCoast's Avatar
Originally Posted by houm_wa
I wouldn't do it.
X2
It's not like there is a ton of fluid in there anyway... might as well get the good stuff or at least a known name brand like Royal Purple.
Old May 2, 2017 | 07:22 PM
houm_wa's Avatar
yep....it's a Land Rover. Don't dick around....and then curse it later.
Old May 3, 2017 | 08:46 PM
cmb6s's Avatar
If you want to save some money, the GM (ACDelco) 92184900 is supposed to be the same Castrol SAF Carbon Mod fluid that our locking diff uses. I would definitely go with that over Ravenol.
Old May 5, 2017 | 11:44 AM
djkronik57's Avatar
How important is replacing all the plugs on the diffs/tc with new? Not necessary?
Old May 5, 2017 | 01:53 PM
Coleroad's Avatar
No it's not necessary to change the plugs. I have changed mine atleast every year, and have never changed the plugs.
Marcus DaCosta
Mar 1, 2012 07:38 PM
mrossipir
Jan 1, 2009 10:54 AM
workingclass
Sep 19, 2008 06:34 PM
workingclass
Sep 19, 2008 03:14 PM
gtiturbolr3
Apr 15, 2008 03:26 PM
