Locking issues/can’t open truck
Hi all,
Newly minted LR3 owner here. Truck is a 2006 SE V8. I recently had it delivered from the auction and was going over it. Suspension needs attention but it run and drives. I was headed out of town for a few days and since both key fobs are dead, I locked it from the dash switch.
However, now I can’t get the truck open. I tried both manual keys in the drivers side door. The key turns but the central locking doesn’t seem to work and none of the doors will unlock. I put in a new battery in the truck before I left so I assume it can’t be a battery issue.
While I wait for AAA, does anyone have any ideas what may have happened? I moved getting new fobs to the top of my to-do list.
Thanks in advance.
Thanks in advance.
The door does not have central locking, its an emergency entry only way to get into the vehicle. Your fobs may be dead or it may be a faulty wire on the passenger side sill, a rather common issue due to water ingress. So pressing the dash buttons to unlock things stopped working is what you are saying tho? I would check the appropriate fuse.
lowerrb
Jun 14, 2013 07:25 AM
