Lots of transmission flush threads.. Here's a potentially $$ saving tip.
Old Apr 14, 2016 | 03:44 PM
MrWesson's Avatar
Default Lots of transmission flush threads.. Here's a potentially $$ saving tip.
So I hope this doesn't cause a shi*storm and I'll preface this with
*Do you own research on the subject.
*Your car/your risk
So whats the tip?
Ford Mercon SP has been independently tested and proven to be equivalent in makeup to ZFlifeguard6.
Why would you care?
Mercon SP is around $5 a liter/quart vs $30+
Its available locally, globally, and did I mention its cheap.
"I'm not cheap why would I consider this crap?"
Want to flush your transmission? You can buy the Mercon sp fluid run it for 100 miles drain/fill(With ZFlifeguard6 if you desire).
My opinion is you'd spend better money running Mercon SP with a metal pan/filter. You can buy the filter for under $15 and change more frequently.
I've been running it for about 1,000 miles and plan on doing the Metal pan mod, drain whats in there now(mercon), refill with mercon, and drain/fill in 20k miles or whenever I feel like it down the road.
Blackstone independent test Mercon SP vs Lifeguard 6
Mercon SP was developed for ford 6 speed ZF transmissions FWIW.
Transmission Fluid Replacement 2006 Range Rover HSE
Lifeguard6 = Mercon SP?
Automatic Transmission Fluid (ZFLifegaurd6=Ford Mercon SP) [Archive] - Bimmerfest - BMW Forums
Old Apr 16, 2016 | 08:38 PM
Paul Flannigan's Avatar
Where did you source the metal pan? Did you need shorter bolts?
Old Apr 20, 2016 | 07:09 AM
jafir's Avatar
I used mercon sp in my previous lr3 with no issues. I'll probably use it in this one too.
kid A
Jul 22, 2015 05:14 PM
pedro_malo
Jan 14, 2012 08:30 AM
wannabe
Jan 24, 2011 10:42 AM
aircraftguy
Jul 16, 2009 12:50 PM
tunernewb92
Jun 23, 2009 04:44 PM
