LR 3 suspension quirk
I have a 05 LR3, after replacing the front lower control arms the traction control light began. to appear in a slight LH turn, after about 15 miles on a straight road the air suspension, brake, and traction control warning lights lights came on and the lights on the air ride selection toggle and special vehicle control **** went off. If I stop and turn the vehicle off and restart all his fine again. However this problem will reoccur at random intervals, always (so far) rectified by restart ing the vehicle . I had the front end aligned and steering angle sensor recalibrated. It almost acts as if there is a loss of power to the control module. any suggestions? thanks
How charged up is the battery?
Did you leave it on over night after you brought it home?
These things are electron hogs, so make sure the battery is fully charges cables are not corroded and the alternator is working.
But this sounds like mine every time I drive it to the shop for a 4 wheel alignment after I have replaced suspension parts. ( Hopefully will be making THAT trip again before the end of the month)
May need to recheck the steering calibration.
Jeff
Jeff
also as mentioned below, it sounds like a steering angle sensor out of calibration.
Foxsport7
10-19-2020 03:03 AM
jennaalvarez31
05-05-2018 02:38 AM
Doc Fluty
10-13-2013 08:03 AM
