Lr3 cheap sunroof drain repair
Old Sep 8, 2018 | 05:49 PM
TOM R's Avatar
Default Lr3 cheap sunroof drain repair
Here are pics how i had fixed mine, removed bad end made up a replacement with 1/2" cpvc i had on hand and sealed it on outside of body with right stuff
Old Sep 8, 2018 | 05:50 PM
TOM R's Avatar
Hardest part was removing and reinstalling the fuse box
Old Sep 8, 2018 | 06:22 PM
DakotaTravler's Avatar
That junction box is a total pain. I suggest doing the passenger side first so when one gets to the drivers side its a pleasant surprise. Did you do the two rear drains also? I replaced both rear drains but I still have the originals on hand since they are fine.
Old Sep 9, 2018 | 05:54 PM
TOM R's Avatar
I only did the pass front rest are fine for now
Old Sep 24, 2018 | 11:34 AM
TOM R's Avatar
Drivers front went in the last down pour lol
drivers front i made the same fitting as before but i used right stuff and glued on the inside of the body since there is no access outside
to do this side drop the bottom panel and the one under the steering column u need 2 hands to push the new fitting up the hose
im sure the rears will be next
DakotaTravler
Sep 6, 2022 08:46 PM
TOM R
Jul 27, 2018 08:01 PM
sputnik62
May 28, 2018 10:50 AM
trive2
LR2
Aug 27, 2017 06:16 PM
dustinkantu
Nov 16, 2016 03:19 PM
