Lr3 sunroof drain ends
Old Jul 26, 2018 | 11:43 AM
TOM R's Avatar
Default Lr3 sunroof drain ends
So the one above the passenger fuse box went and with all this heavy rain water is pouing in, has anyone found an off the shelf item to replace that elbow
Old Jul 26, 2018 | 05:15 PM
TOM R's Avatar
Perminant fix remove bad original elbow, make new elbow from 1/2" cpvc and a 90* fitting, glue and install, the new pipe fits hole in body perfect and the drain tube fits tight inside it, should never fail or clog, used some right stuff on outside for good measure to seal body
Old Jul 26, 2018 | 05:18 PM
TOM R's Avatar
https://photos.app.goo.gl/C2yF7NPBBB1VxaHz5
Old Jul 27, 2018 | 12:06 PM
Best4x4's Avatar
A drain out of a Honda = looks exactly like the one found on an LR3. I fixed mine before I saw the Honda drain. I just used some clear silicone tubing slid firmly over the original drain tube, ran thru the hole in the body with a longer piece vs the OEM nipple & held in place with some thick black duct tape. Zero issues after that repair!
Old Jul 27, 2018 | 04:06 PM
TOM R's Avatar
Definitely plenty of better cheaper
​​​​ways than factory
Old Jul 27, 2018 | 08:01 PM
DakotaTravler's Avatar
The Honda part is far too large to fit onto the tube or into the frame.
aftermath431
Jul 13, 2024 12:40 PM
willstevens
Oct 6, 2022 07:41 AM
ljdiscovery
Dec 29, 2014 05:29 PM
Marcus A McDuffie Sr.
Oct 15, 2014 03:34 PM
S4poor
Jan 3, 2008 02:12 PM
