LR3 fuel pump wiring route???
Old Mar 25, 2021 | 09:04 PM
DakotaTravler's Avatar
Default LR3 fuel pump wiring route???
Long store short, pretty sure I have a bad positive wire to my pump. Parked truck for a few days and came back to it being dead. Not ruling out little critters. Anyway, replaced the pump, fuse, relay, etc, etc... I get voltage at connector to the pump when the relay is jumped, but the voltage reading is about 1 volt lower than system. Then when load is applied, nothing. So thats a classic wiring is barely attached and can pass voltage for a meter to read, but under load there is just not enough wire. The harness from the pump goes to the rear and from there no clue. So if anyone knows if it stays outside all the way to the front or is routed inside along the sills, would love an answer!
By the way, if you ever drop a tank have new bolts, washers and j-nuts on hand.
Dalea
Nov 2, 2016 04:33 AM
vsop4me
Oct 8, 2014 10:32 PM
james taylor
Mar 18, 2011 07:20 PM
dev99disco
Sep 22, 2010 06:15 PM
joshtwining
Dec 8, 2009 02:42 PM
