LR3 - HVAC - Low Density Foam Tape Help!
Old Mar 25, 2023 | 06:56 PM
gorgalor's Avatar
6th Gear
Default LR3 - HVAC - Low Density Foam Tape Help!
I'm trying to track down either a part number or supplier of low density foam tape for HVAC ducting for a 2007 LR3. I've successfully ripped out every shred of ducting (as well as dash components) to replace a restricted evaporator. And in the process all the antiquated insulation tape sealing ducts and around the air handler dissolved.
Based upon my measurements, this is approximately 1/4" (6.4mm) x 1/4" (6.4mm) low density foam tape. Yet, all of my Google search results have resulted in nil. And I can't seem to find any part numbers on LR sites. I might be the most incompetent Gen X interwebs searcher to grace this planet. For every derisive comment I get about using a search function to try and find the thing, or check a different thread... I'm going to turn it into a drinking game and kill a cube of Coors Lights. I'd really appreciate it if some kind soul could toss me a link to solve my woes. May the mercy of a kind internet stranger save me.
So, where can I find this mystery product?
Thanks a million. You know how much your help means to me!
Old Mar 27, 2023 | 11:02 AM
nevillusa's Avatar
Something similar to this will work - https://a.co/d/bP6zHPh
Old Mar 27, 2023 | 08:37 PM
gorgalor's Avatar
6th Gear
Is it a product you've used before? I was concerned about high-density closed cell foam. Main difference is that low-density open cell is much more compactable.
Appreciate the help!
Old Mar 27, 2023 | 09:23 PM
DakotaTravler's Avatar
What Nevill linked is what I use too. Window foam, basically. Compresses down VERY well.
Columbiar
Jun 5, 2021 08:33 PM
lior3
Apr 30, 2008 03:21 AM
