lr3 loud engine video
Old Sep 18, 2014 | 01:43 PM
TOM R's Avatar
Default lr3 loud engine video
This sounds as little different on the video, from what I can tell its coming from the drivers valve over toward the front? Ideas before I start the tear down, I do not believe its the crank, wrong tone from wrong area
There is a valve tap on the drivers side you can't hear in the video
Old Sep 18, 2014 | 04:53 PM
unseenone's Avatar
Wow, sounds like something serious... crank, head gasket? I'm not sure.
Old Sep 18, 2014 | 05:21 PM
TOM R's Avatar
Sound is definitely in the top end on one side, cam?
Just pulled a code with ug 2119 probly due to the batt being unhooked
Old Sep 19, 2014 | 09:11 AM
TOM R's Avatar
Is this an interference engine? I see the v6 is
Old Sep 22, 2014 | 02:36 PM
TOM R's Avatar
Are these hydraulic? The manual said solid aluminum shim less lifters iirc
nh9095
Jan 14, 2019 12:36 AM
Giverny
Mar 11, 2010 08:57 AM
paulfromperu
Apr 19, 2009 10:14 PM
tcbinaflash
Jan 8, 2008 04:23 PM
JustinFanatic
Off Topic
Nov 27, 2007 12:28 PM
