Lr3 over heating
Old Aug 8, 2014 | 09:19 PM
SWAINROVER's Avatar
Default Lr3 over heating
I'm noticing my lr3 is trying to overheat at times . Any thoughts
Old Aug 11, 2014 | 03:04 PM
MoShadeTree's Avatar
You need to perform the same basic checks as you would with any water cooled vehicle.
1) Check Coolant Level
2) Check for Coolant Leak
3) Check for debris block the raditor air flow
4) Check fan for missing or bend blades
5) Check fan Clutch for proper operation
6) If above checks don't solve problem - Replace Themostat
7) Check raditor for poor coolant flow.
Of Course - All these checks are assuming that you have not overheated the engine to the point of warping the cyl. heads.
Good Luck
SolbergFanBoi
Mar 5, 2012 07:05 PM
unco
May 13, 2011 07:27 PM
99Landrover
Mar 15, 2006 11:08 PM
budley62
Jan 24, 2006 01:28 AM
budley62
Jan 3, 2006 05:36 AM
