Lr3 parking brake light
Hello I have a 2008 lr3 a few weeks ago a red park icon started flashing on the upper part of my speedometer its continuously flashing and sometimes when I start it I get the amber yellowish brake icon on in the middle gage with a triangle in a almost complete circle as well but usually if I turn it off and restart the car those two go away the vehicle does not seem to have any other effects from these lights the emergency brake does not seem to be engaged however when I turn the vehicle off I get a message saying the emergency brake is off
thanks for any help info ideals
Parking brake is drum brake inside the rear disc rotors. The plastic gears in parking brake servo is unfortunately a common failure and expensive repair. Best practice to replace the rear brake dust shields too if that are showing corrosion where the parking brake cable intersects.
Stay away from Atlantic British (aka https://www.roverparts.com/) for replacement - mine and others were missing parts that causes the replacement to immediately strip again. This created a situation where my truck was out of commission for over a month.
SOMEONE PLEASE create a simpler parking brake solution / cheaper repair option !!
Expensive? I dont see how, the hears have been available on their own for some time. What was missing from the AB replacement thought? Details required.
Anyway, we dont know for certain the gears in the module are the issues until looked at. Often the system itself is neglected and needs service/adjustment. It uses a setup that monitors tension on the cables, so if they are stretched, out of adjustment or the shoes are damaged it can cause faults. I personally have seen more issues with neglect/adjustment than damaged gears. Like any system, its needs maintenance - especially when as old as 2008.
Maybe, but two I took apart that howled, one being on my 2006, were just adjutant issues and the gears were fine. But when it happened I manually backed off and disabled the system. I *think* broken gear are more a result of a system being out of adjustment and then allowed to carry on enabled, where its constantly adjusting and banging up the gears. I dont think its the other way around, where the gears seem to fail for no reason and then cause issues. Basically, broken gears are a symptom of abuse not cause. But thats just a guess based on what I have personally seen.
edit: Oh, I will add that I plan to buy gears anyway and rebuild mine more as a matter of longevity/maintenance. Plastic gears are just silly in the first place.
houm_wa (09-29-2021)
