Lr3 rear brakes
Old May 31, 2022 | 04:31 PM
Philip Chan's Avatar
Default Lr3 rear brakes
Hi. So I thought I was sneaky and I ordered a set of calipers for a v8 LR3 not my V6 simply because I thought there was not a difference. Well there is, as you know, as the calliper on the v8 takes a larger rotor. So I have the choice. Either replace the calliper bracket to one that fits a v6 or get bigger v8 rotors that will fit the pads and bracket properly. Either way, cost wise, it’s a wash. Thoughts?
Old May 31, 2022 | 05:51 PM
houm_wa's Avatar
Do you have different wheels than those that came with the vehicle? If not, I don't think they are going to fit right on with the larger assembly.
Old May 31, 2022 | 06:29 PM
Oceanguy33's Avatar
Good point. I have 20s on there right now, but 18's is what i want to run. I may have my answer right there....
Old May 31, 2022 | 06:30 PM
loanrangie's Avatar
17's fit on stock V6 brakes, V8 brakes require 18" rims so that may decide for you.
Old May 31, 2022 | 08:52 PM
DakotaTravler's Avatar
If you are running 18s eventually, then you are fine. Just to finite the details, the calipers themselves I believe are the same. Its the caliper bracket that is different. And yes, the rotors too. So if you are just wanting to refresh the calipers for now you can just swap brackets from one to the other and enjoy the new calipers then later swap back when the rotors come in.
jmac
Jul 30, 2020 09:43 PM
blottervet
Aug 30, 2019 09:23 PM
BostonLR3
Jun 10, 2015 09:41 PM
Markmetzger9494
Jun 4, 2015 09:13 PM
EL GALLO
Mar 9, 2010 10:24 PM
