LR3 Suspension Fault
Old Jun 21, 2018 | 10:47 AM
pscorbin's Avatar
8th Gear
Default LR3 Suspension Fault
I have a 2006 LR3 with a red suspension error that reads :suspension fault and special programs off. The compressor does not engage. The ODBII shows no error codes. I have tried the following without any success:
-Replaced relay
-Checked all fuses related to the suspension
-bypassed the relay and the compressor motor runs
-replaced the front EAS suspension valve block
-replaced the battery
Any suggestions? My only thought were the compressor is gone or height sensors?
Old Jun 21, 2018 | 11:12 AM
houm_wa's Avatar
When you bypass the relay and run the compressor motor, does the EAS raise?
Old Jun 21, 2018 | 12:13 PM
pscorbin's Avatar
8th Gear
I only let it run for about 10-15 seconds, but it did not raise.
Old Jun 21, 2018 | 02:19 PM
houm_wa's Avatar
Hmmm....so maybe the motor is running but it's not making pressure.
Does the red suspension fault come on at speed or even at a stand-still?
Old Jun 21, 2018 | 02:25 PM
pscorbin's Avatar
8th Gear
The red suspension light is on as soon as I start the engine. The suspension is totally deflated so I haven't driven it. I've let it idle for several minutes to see if the suspension light would change to amber or the compressor would inflate, but neither have happened.
Old Jun 21, 2018 | 03:54 PM
houm_wa's Avatar
I think it's the compressor.
Old Jun 21, 2018 | 05:13 PM
pscorbin's Avatar
8th Gear
Do you think it would be an issue if I bypassed the relay for longer to see if it would inflate? I just don't want to burn something up.
Thanks!
Ken@stricksbbq.com
Mar 26, 2019 06:36 AM
kwackwacker2
Jun 2, 2017 10:42 AM
kwackwacker2
Jun 1, 2017 09:47 PM
kwackwacker2
Jun 1, 2017 03:21 PM
