LR3 Suspension Troubleshooting: Right Rear Won't go up or down
Old Aug 2, 2023 | 10:01 PM
HaSlEt's Avatar
That's a late tomorrow evening activity for me ... will report back.
Old Aug 4, 2023 | 08:28 PM
HaSlEt's Avatar
'Twas the valve. So, I removed the strut, there was pressure built up between the strut and airline inbetween the valve. Service tested the valve with the gap tool, "raised" the RR, and felt a trickle of air flow. Kept doing this for about a minute, something popped loose, and now the valve is working.
Thanks for helping me troubleshoot, got to the root cause. I can only guess that maybe one of the o-rings got stuck in the valve and hopefully now it is loosened up. I also believe that pressuring up against atmospheric pressure helped to relieve the blockage as opposed to pressure already built up within the strut.
Old Aug 5, 2023 | 09:46 AM
DakotaTravler's Avatar
Odd.. I think this issue will come up again though. Something might be off with that block a bit.
Old Aug 5, 2023 | 11:14 PM
HaSlEt's Avatar
Your intuition was right. There was a desiccant bead in the corner valve. I have since swapped it and installed the Arnotts. The suspension hopefully is almost as good as new now.
Old Aug 5, 2023 | 11:17 PM
That is ever more odd since the desiccant is contained in a well filtered housing. A bead can not make its way into the system unless someone did a total **** job on a compressor rebuild and bead got into the system? Color me confused. None the less, at least you know the cause AND it is working!
Oceanguy33
Oct 27, 2024 07:34 AM
keninnc
Aug 24, 2022 09:25 PM
jmcmurra
Dec 7, 2012 04:26 PM
Charles68
Apr 6, 2012 08:45 AM
