LR3 Terrafirma front skid plate install?
Before I dive under and puts around with the skid plate install, I am wondering if both factory plates come out or does it go on top the existing? The directions seem to indicate the front plastic one comes off, of course, but its not really clean on the others.
"Remove the bolts in the standard under-shield that is bolted between the front suspension wishbones and then remove this standard under-shield (These mounting holes will be re-used to secure the centre of the new steering guard)."
https://www.roverparts.com/Instructi...terrafirma.pdf
Right, the plastic comes off as I mentioned too but its not exactly clear as to which bottom one as there are two. Guess I will find out when I install it, just waiting for the install kit from Terrafirma to arrive. UK post, so that may be a while.
zbysiu23
Dec 6, 2016 04:41 AM
cmb6s
May 8, 2014 10:39 AM
