LR3 Tilt
Old May 1, 2014 | 10:08 AM
dfauver1's Avatar
6th Gear
Default LR3 Tilt
Does anybody else have an LR3 that seems to tilt to one side? Mine seems to tilt towards the passenger side about an inch lower than the driver side. Should I be concerned?
Old May 1, 2014 | 12:38 PM
jafir's Avatar
Mine does too. I haven't worried too much. What's funny is that it looks like it's leaning but when I busted out the tape measure once, it was right. ??? Maybe I've got a slow leak somewhere and it would measure different if I let it sit longer.
Old May 7, 2014 | 01:38 PM
unseenone's Avatar
You need to get a height calibration done periodically. This is typical, from bushings settling, etc. If you do new bushings, then it is worth getting it done. Best to do the height calibration and alignment together if possible. It will require a dealer or independent with an Autologic or similar system.
DISCO1995
Oct 26, 2011 11:29 AM
mike031
Aug 13, 2009 10:12 AM
endneu913
Oct 16, 2007 10:19 PM
xb70valkarye
Appearance & Camping Set Ups
Aug 25, 2006 01:28 PM
herovc
Oct 11, 2005 08:39 AM
