LR3 Tow reflash?
Old Oct 18, 2019 | 03:10 PM
lawsonmahoney's Avatar
Default LR3 Tow reflash?
Hey guys. I just did a search for this, but can't find anything on it. The short story is that I installed a towing wiring harness from AB. They mention I may need to get my body control module reflashed or something along those lines. Local dealer wants to charge me $350 (2 hours labor) to get it done which seems totally ludicrous. Any experience with this? Is it a true requirement? I don't want to waste money on something I don't need, but also don't want to do way more than the cost to reflash a system in damage to my suspension.
Old Oct 23, 2019 | 12:46 PM
bump for ideas. Local dealer wants me to pay 2 hours labor, or $350 bucks for this. Blows my mind.
Old Oct 23, 2019 | 01:27 PM
Did nothing to either of mine when I added the wiring. Both did what they were supposed to do. Even added a brake controller no issues using the factory body harness plug in
Old Oct 26, 2019 | 04:16 AM
Globetrotter448's Avatar
The factory harness only goes from the LH side cubby hole down to the towball area and just plugs into existing connectors so should not be a problem unless the one you are getting does not use the standard connections
Old Oct 26, 2019 | 05:31 AM
enb54's Avatar
If you added the wiring and the trailer stuff works, everything is OK. Mine all works (2007 LR3) and nothing was reflashed...
Old Oct 26, 2019 | 07:42 AM
Sounds good guys. I thought the body control module would be all confused just based off the context clues from the directions. Thanks for the help
theman
Jul 15, 2014 07:17 PM
LeethalG32
Sep 1, 2012 09:59 PM
gtokid
Dec 19, 2010 04:09 PM
Rejeep
Oct 30, 2009 06:50 PM
Madtown
Jul 4, 2009 10:50 PM
