Lr3 transmission
Old Apr 3, 2023 | 10:20 PM
Jaygee's Avatar
Default Lr3 transmission
2005 lr3 not shifting until 6-6500 rpm. Shift perfect in manual. Sometimes a Christmas tree of lights come on other times there's no lights. Every so often it will shift fine.
Old Apr 4, 2023 | 05:02 AM
loanrangie's Avatar
Could be numerous thing but i'd start with alternator output and battery condition, check fluid level and if it has been serviced previously.Transfer case electrical connector can get corrosion on it causing various xmas tree lights and poor gear shifting, can also be in need of a valve body or full trans rebuild if mileage is high. You need to get access to a diagnostic scanner to confirm what the actual cause is.
Old Apr 4, 2023 | 05:30 PM
DakotaTravler's Avatar
Yeah... need codes really. Can be numerous causes, even engine related (the transmission relies heavily on the MAF for example).
nixnorris
Mar 5, 2022 11:12 AM
walker139
Oct 5, 2021 04:59 PM
jfmartin25
Jan 24, 2015 10:17 PM
Joentuff
Mar 14, 2011 10:02 PM
1961 Lincoln
Jan 13, 2011 10:35 PM
