LR3 Transmission Sleeve replacment
Old Mar 13, 2013 | 06:10 AM
Simonscyclist's Avatar
4th Gear
Default LR3 Transmission Sleeve replacment
Has anyone change this out? and if so how hard is it Land rover wants to charge me 180 for parts and 650 for labor. Sounds a little high to me I know that the trans oil is expensive and i understand that but if its not that hard to do ill do it myself your feed back is greatly appreciated. FYI the transmission sleeve only has a class I leak. so I have time to ffix it or save up the 850 Bucks.
Old Mar 13, 2013 | 08:34 AM
LR Techniker's Avatar
Class 1 leak? You must be military, I have not heard that term since I was stationed at Ft. Stewart, GA.
$180 in parts sounds cheap to do the job correctly. The pan has to come off to do the sleeve and the filter is integrated into the pan, so its common practice to do the sleeve and pan at the same time. List price on the pan is $300 by itself, not to mention the $30/qt fluid.
The labor sounds dead on for a dealership (hourly rate at local LR dealer here is $140/hr, book time is about 4.6 hours).
Search around in this forum, I think there is a DIY posted on how to replace this stuff.
You can buy the parts from ZF (the manufacturer of your trans) for much cheaper than the dealer. ZF Parts Eriksson Industries
LR trans fluid for this vehicle is relabeled Lifeguard6. You can purchase Lifeguard6 cheaper.
Old Mar 13, 2013 | 08:55 AM
And shop manual pages attached.
File Type: pdf
File Type: pdf
Old Mar 13, 2013 | 06:29 PM
4th Gear
Yes Im in the Military Stationed in DC. thanks Savannah Buzz Oddly enough I was born and raised on Tybee Island thanks for the diagram but doesn't really tell me if its easy or do I just need to cough up the money? As for the parts from British Atlantic new oil pan/oil/ and the sleeve with shipping 260.
Old Mar 13, 2013 | 07:08 PM
If review of the shop manual leaves you with a lot of uncertainty, save up for the repair, hunt for an indy shop. You don't want to start a project, and leave yourself with no ride, and a big towing bill to the shop. You might not have the tools, work space, or available time.
Old Mar 14, 2013 | 08:32 AM
ghengis86's Avatar
I was on Tybee last week. Had to go to Savanah for work, so took the fam. A little cold, but a neat little place. Good shrimp. Ft. Polaski was pretty cool too. Went up the Charkeston on the way back and hit up Patriots Point and Ft Sumter. Good people down there.
Old Mar 14, 2013 | 08:34 AM
ghengis86's Avatar
Oh, and you have to jack up the engine to get the tranny pan out (tall, integrated pickup tube on the pan). If you do it yourself, be sure to let me know how it goes. I want to do it come springtime.
Old Mar 18, 2013 | 08:11 PM
unseenone's Avatar
Where are you located, there are good indy shops all over the place. Maybe someone can recommend one.
matt5963
Jan 16, 2012 08:58 AM
Rich 00 DISCO
Apr 24, 2009 11:18 AM
MLandry7
Dec 3, 2008 09:38 AM
Chillbilly
Jun 4, 2008 03:51 PM
cpl55
Apr 20, 2007 01:06 PM
