LR3 Transmission Swap Help!
Hey guys I know this is an old post but I’m looking to buy a 2006 Land Rover LR3 HSE the guy said he changed the transmission and still giving him same codes I’m guessing the issue is what these guys were taking about the Mechatronics but I’m sure there’s no way to get the original Mechatronics
the codes is giving is p0735 and p0729
any help would be appreciate!!!
OBD Code P0735refers to
This diagnosis monitors actual gear position by checking the torque converter slip ratio calculated by Transmission Control Module (TCM) as follows: Torque converter slip ratio = A x C/B A: Output shaft revolution signal from revolution sensor B: Engine speed signal from Engine Control Module (ECM) C: Gear ratio determined as gear position which TCM supposes If the actual gear position is higher than the position (5th) supposed by TCM, the slip ratio will be more than normal. In case the ratio exceeds the specified value, TCM judges this diagnosis malfunction.
Symptoms
Possible sumptoms of OBD code P0735
- Engine Light ON (or Service Engine Soon Warning Light) - Incorrect transmission shifting
Causes
Possible causes of OBD code P0735
- Low transmission fluid level - Dirty transmission fluid - Shift solenoids - Transmission mechanical problems - Transmission hydraulic control circuit The Error code is generally activated on detection of the following conditions: P0735 is detected when A/T cannot be shifted to the 5th gear position even if electrical circuit is good.
P0729 is similar to P0735 but relates to 6th gear.
nh9095
01-14-2019 12:36 AM
cold_surfer
02-14-2008 07:36 PM
