LR3 turning and skipping/ rubbing/ growling
Old Nov 15, 2018 | 10:04 PM
  #21
abran's Avatar
Fronts hardly ever fail, the rears always do.
look at the rubber donut on the carrier bearing to be ripped or grease that has been flung out from the front cv.
Old Nov 16, 2018 | 07:35 PM
  #22
Atticus_6147's Avatar
So tonight I crawled underneath and examined the Carrier. The rubber looks good but you can move the driveshaft up and down and side to side. Is that bad or normal?
Also, jacked up the back and both tires are firm side to side and top and bottom. Does that eliminate the rear hubs?
What should I check next?
Old Nov 17, 2018 | 09:31 AM
  #23
abran's Avatar
Rear hubs are eliminated.
to see the rubber you really should remove the heat shield that covers the driveshaft.
there should be some play, but only what force you exert on the intact donut. I would check again with heat shield off and use a flashlight.
if it’s good, I’m saying diff.
Old Nov 20, 2018 | 11:44 AM
  #24
So today I crawled underneath her and changed out the transfer case fluid because I've never done it and couldn't tell you the last time it was done .
The fluid that came out looked like pale strawberry milk. I'm guessing water has been in there. I drained it all out completely and even flushed it a little with new fluid.
Filled her up to spec but the problem is still there. Does the transfer case come into play while turning? Is mine toast?
I believe there is a locker or motor on the transfer case. Could that be messed up and always locking it so when I turn it is locked?
Old Nov 20, 2018 | 12:42 PM
  #25
abran's Avatar
Your symptoms do not sound like T case.
Cant remember, did you check the rear diff fluid?
Old Nov 20, 2018 | 01:24 PM
  #26
Hey,
That's a bummer. I was hoping it had something to do with the water in T-case.
The rear diff fluid was changed about a 1000 miles ago. It was dark and there was some sludge on the plug but really no metal shavings or chunks.
Old Nov 20, 2018 | 02:34 PM
  #27
Most likely the sludge on the plug was metal shavings.
Old Nov 20, 2018 | 11:14 PM
  #28
Does anyone know if it is possible to drive the lr3 without the front drive shaft? I'm trying to see if I can narrow down where the issue is coming from.
Old Nov 21, 2018 | 05:51 AM
  #29
Never heard of anyone trying it. It might work but I would be afraid to do it.
​​​The center differential on the transfer case is electronic. It could simply fault out or it could burn itself up. It could also just drive along happy as can be.
Old Nov 21, 2018 | 09:51 AM
  #30
abran's Avatar
You can’t.
Has anyone been able to explain why a front driveshaft or rear for that matter could be causing your symptoms?
I can’t find a correlation, but what do I know.
