Many ECU Faults LR3 not starting
Old Aug 17, 2024 | 11:44 AM
wesmc's Avatar
Any updates? I am considering pulling my cluster from my 2008 RRS and shipping it for repair. I am getting random uo167 and have tried everything.
Old Aug 19, 2024 | 07:47 AM
gmtech's Avatar
sending it to cluster fix today. hopefully in a week or so ill let ya know the good news!
Old Aug 26, 2024 | 08:16 AM
jbullock78's Avatar
Yea Full cluster replacement for the issues.
Took a while due to the COVID issues, but with new cluster, no issues on that front since.
The only issue I have and cannot figure out, is the Lean Codes that continue to plague me.........
Old Aug 26, 2024 | 09:04 AM
gmtech's Avatar
i also had lean code issues i batttled in spring. smoke tested multiple times with shop grade smoke machine. replaced air duct from box to throttle body and then mass air flow sensor. then reset fuel trims. i think reseting fuel trims is what is needed to verify fix. i feel like i may have only needed air duct.
Old Aug 26, 2024 | 09:55 AM
wesmc's Avatar
Awesome...i will pull my cluster out today! Thanks to you guys for coming back with updates.
Old Aug 26, 2024 | 04:03 PM
P-Bod's Avatar
Clusterfix repaired my 2007 when I first got it in Feb. 2022 with 105k miles. Currently just over 132k miles and no problems since. My 2006 now with 174k miles never had the cluster problem.
Old Aug 26, 2024 | 07:33 PM
wesmc's Avatar
what symptoms were you having?
Old Aug 27, 2024 | 04:10 AM
P-Bod's Avatar
While idling, the flashers would start, doors would lock/unlock, cluster messages of HDC fault, no DSC, transmission fault, radio message of vehicle shutting down. If I turned the key off it would not restart - no crank with key in starting position. After some time, 15-45 minutes, it would crank, start and run fine.
Pushing the trip reset button on the cluster triggered this condition once. Also, unplugging the cluster mimicked the same condition, but I obviously couldn’t read the cluster messages.
Old Sep 9, 2024 | 07:40 AM
gmtech's Avatar
got cluster back. has been 130 miles over 3 days. all problems fixed. mine included no crank no start. 08 LR3 HSE 166,000. only thing i wish clusterfix would do better is let you know what they found/fixed.
Old Sep 9, 2024 | 02:00 PM
wesmc's Avatar
Awesome...I am gonna send mine off! Thanks
