messsge Special programs not available
Old 04-29-2018, 06:22 AM
Viking1's Avatar
Default messsge Special programs not available
Ok before I give in and have it diagnosed by LR can anyone offer any info on where to look for the cause of this error ? Special Programs not available. It’s the only error showing up and is always there. I checked the battery it’s good also load checked it. Brake lights all good
I did a complete brake job about a month ago and also replaced the brake wear sensors.
Old 04-29-2018, 10:48 AM
houm_wa's Avatar
Maybe try a hard reset....
Old 04-29-2018, 11:12 AM
Viking1's Avatar
Default Hard reset
Yes I did disconnect the positive terminal for a few min. No change
Old 04-29-2018, 11:23 AM
houm_wa's Avatar
A hard reset involves connecting the two cables for a few minutes.
Old 04-29-2018, 11:49 AM
Viking1's Avatar
Default Hard reset
Ok I will do that I wasn’t sure that’s why I specified I only disconnected the positive thanks I’ll disconnect both + and - and see if that will reset the computer.Ill let you know
Old 04-29-2018, 12:22 PM
houm_wa's Avatar
Disconnect both and then touch them together!!
You will likely need a length of wire or cable. I've never actually done this, but if I were to do so, I'd use a jumper cable
Old 04-29-2018, 12:26 PM
Viking1's Avatar
Really that’s a hard reset disconnect them both and touch them together?
Old 04-29-2018, 12:44 PM
abran's Avatar
You need to read the codes. It’s all guessing if not.
A common problem is corrosion on the transfer case module connector pins. If you need to start guessing without swapping parts that is the first place to start.
Old 04-29-2018, 01:22 PM
Viking1's Avatar
Where’s the transfer case module located ? I’m holding off on the hard restart
Old 04-29-2018, 02:06 PM
abran's Avatar
Remove the battery, first module behind it. Second is the PCM or engine control module
Quick Reply: messsge Special programs not available
