messsge Special programs not available
Old Apr 29, 2018 | 06:22 AM
Viking1's Avatar
Default messsge Special programs not available
Ok before I give in and have it diagnosed by LR can anyone offer any info on where to look for the cause of this error ? Special Programs not available. It’s the only error showing up and is always there. I checked the battery it’s good also load checked it. Brake lights all good
I did a complete brake job about a month ago and also replaced the brake wear sensors.
Old Apr 29, 2018 | 10:48 AM
houm_wa's Avatar
Maybe try a hard reset....
Old Apr 29, 2018 | 11:12 AM
Viking1's Avatar
Default Hard reset
Yes I did disconnect the positive terminal for a few min. No change
Old Apr 29, 2018 | 11:23 AM
houm_wa's Avatar
A hard reset involves connecting the two cables for a few minutes.
Old Apr 29, 2018 | 11:49 AM
Viking1's Avatar
Default Hard reset
Ok I will do that I wasn’t sure that’s why I specified I only disconnected the positive thanks I’ll disconnect both + and - and see if that will reset the computer.Ill let you know
Old Apr 29, 2018 | 12:22 PM
houm_wa's Avatar
Disconnect both and then touch them together!!
You will likely need a length of wire or cable. I've never actually done this, but if I were to do so, I'd use a jumper cable
Old Apr 29, 2018 | 12:26 PM
Viking1's Avatar
Really that’s a hard reset disconnect them both and touch them together?
Old Apr 29, 2018 | 12:44 PM
abran's Avatar
You need to read the codes. It’s all guessing if not.
A common problem is corrosion on the transfer case module connector pins. If you need to start guessing without swapping parts that is the first place to start.
Old Apr 29, 2018 | 01:22 PM
Viking1's Avatar
Where’s the transfer case module located ? I’m holding off on the hard restart
Old Apr 29, 2018 | 02:06 PM
abran's Avatar
Remove the battery, first module behind it. Second is the PCM or engine control module
