Need help with codes
Old May 16, 2023 | 11:18 AM
LR3Donkey's Avatar
Did you pull up the plastic trim on the drivers side door well? A common place for wires to come apart is about 12" down from the fuse panel where the wires run on floorboard.
Old May 18, 2023 | 10:31 AM
DrBimmer11's Avatar
I will be doing that this weekend. I'll take some pictures and show what I find.
Old May 18, 2023 | 01:09 PM
LR3Donkey's Avatar
Crap, I meant PASSENGER side not the drivers. I'll see if I have a photo I can share later today.
Old May 18, 2023 | 04:38 PM
DrBimmer11's Avatar
I changed out the switch assembly and the vehicle still stays in extended mode when raised to offroad height and then lowered to normal height. Is there a sensor that tells if an object is preventing it from lowering? I know i have some issues with suspension but no suspension faults.
Old May 27, 2023 | 06:39 PM
DrBimmer11's Avatar
Got my rover back. Lean codes were due to a defective MAF sensor I installed or at least that is what the shop is saying. We will see. Also found out my driver side door wasn't locking thanks to someone trying to break in. Just fixed it with the quick fix that everyone has posted. Now I am onto the electrical issue. I checked my fuse boxes and they both look good with no bad fuses, so now onto hunting down a bad wire or wires.
buffalolandy
Feb 13, 2023 12:39 PM
Coyote LR3
Nov 15, 2022 11:46 AM
rud3dog
Apr 26, 2022 07:36 AM
mirepoixmatt
Feb 18, 2020 07:21 AM
