Need a little help check engine light
Old Sep 18, 2020 | 02:53 PM
Bettalove's Avatar
Default Need a little help check engine light
Traveling on my 2006 LR3 66K GOT A CHECK ENGINE LIGHT WITH THE FOLLOWING CODE P0056
Old Sep 18, 2020 | 08:57 PM
DakotaTravler's Avatar
Downstream O2 sensor fault. They usually last a long time because they are after the cats, but they can fail. You can usually go with a cheaper brand for downstream sensors as they are not used for lambda calculations (fuel/air mix).
Old Sep 18, 2020 | 09:34 PM
Bettalove's Avatar
Bank 2 sensor 2 is on the driver side right???
I ordered this one
Old Sep 19, 2020 | 11:08 AM
I dunno, I never know which side is which cause I always replace in pairs.
Old Sep 19, 2020 | 09:25 PM
Globetrotter448's Avatar
If sitting in vehicle, bank 2 is LH side of vehicle
Old Sep 21, 2020 | 10:01 PM
Bettalove's Avatar
I replaced bank 2 sensor 2 on the driver side the one after the cats 🐈 lol problem fix
thanks everyone for the help.
I know I know I need to work on the rust is a project I need to finish I already did the front side left and right wheels now I need to do the back and the center
shmassey1@roadrunner.com
Oct 30, 2009 07:44 PM
wolfie
Jul 2, 2009 05:18 PM
greenlander
Oct 29, 2008 02:13 PM
Sooners
Mar 5, 2008 08:36 AM
NCdiscoII
Nov 16, 2006 12:12 PM
