check engine light
Old Mar 4, 2008 | 10:26 PM
Sooners's Avatar
Default check engine light
Should the check engine light go off by its self?
Mine came on and showed a p0158 code. After it was
cleared the light came back on after a 100 miles or so.
i did not check it, I just assumed it was the same. After
a couple of hundred miles the check engine went off by
it self. I thought it would stay on until cleared.
Mike
Old Mar 5, 2008 | 08:17 AM
okdiscoguy's Avatar
Default RE: check engine light
If the situation that caused the fault is no longer present, the fault will clear on its own. It takes a few start cycles, but it will go off. I think the code will still be stored, though
Old Mar 5, 2008 | 08:36 AM
So, if someone yells fire, how long do you wait till you get out?????????????????
A check engine light is there for a reason, did you replace that failing 02 sensor, how many miles on your truck?
You are going to find out the hard way $$$$$$$$$$$$$$ that you don't pretend there is no problem.
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
