Need a little help here
Old Sep 6, 2020 | 04:34 PM
pagoda's Avatar
If you haven't done it, you could clean the MAF sensor and the throttle body. Both are quick and easy jobs and may help with the rough start. Also, if the car has stood for a long while, old fuel will be an issue. Give it a fresh take of decent fuel and drive it hard and consider adding a can of BG44K. I've found it to be decent stuff; others may have alternative (and cheaper) recommendations.
Just thinking about this some more, if it's sat that long, I'd be more concerned about the brake fluid and coolant than the diff fluids.
Old Sep 6, 2020 | 06:14 PM
Globetrotter448's Avatar
I would expect voltage to be over 14 volts after a start, so you may have an alternator that is on the way out
Andrew kiwi
Aug 10, 2020 02:47 AM
futchs
Mar 9, 2020 03:46 PM
HedgePig
Feb 13, 2020 02:19 PM
K9Hexe
Oct 3, 2014 09:06 AM
carlitonsky
Appearance & Camping Set Ups
Nov 27, 2008 11:59 PM
