New Alternator
Old Nov 6, 2018 | 03:34 PM
cybercop's Avatar
Default New Alternator
Already replaced the Battery. Basically the truck went bat crazy on my son recently and all the lights and error codes came on.
Now, that battery light comes and goes sporadically.
I checked voltage when running and it is steady around 13.5 and 13.6. When I first start it, it immediately goes up to 14.1 but then after a few seconds it rolls back down to 13.5 and 13.6
Just want a vetted sanity check before I go buy a new alternator.
Old Nov 6, 2018 | 03:57 PM
DakotaTravler's Avatar
The running voltage seems a touch low. But its very temperature dependent. Have you cleaned the negative ground at body? Have you inspected the large fusable link for corrosion that sits inside the black plastic box on the positive lead? I had these issues once, but never bad enough for the battery light to come on.
Old Nov 6, 2018 | 04:24 PM
cybercop's Avatar
did not check the negative at the body. Will check that when I get my hands back on it.
Old Nov 6, 2018 | 06:11 PM
abran's Avatar
Not sure about mileage, but the good thing is that changing the alternator is a great preventative measure.
Old Nov 21, 2018 | 12:23 PM
cybercop's Avatar
Whats the best bet on buying a alternator. British Atlantic wants $400
Is there a OE.
I've heard some say that the alternator they bought from Autozone/advance over charged and blew the electronics on their truck. Could be urban myth.
Old Nov 21, 2018 | 03:39 PM
abran's Avatar
Denso is OE. They run around $300 at the wholesalers. Might try LK8.
Old Nov 21, 2018 | 11:08 PM
5280LR3's Avatar
I've had good luck with a re-manufactured by AC Delco unit sourced from Rock Auto. It was the only re-manufactured unit i could find that all bushings, bearings and brushes are replaced with new ones. 24 month warranty.
Most "rebuilt" ones these days seemed to be cleaned, tested and all the gets replaced is what has failed.
If you can find a new Denso for $300 that would also be a good option...
Old Nov 26, 2018 | 03:54 AM
thorgal's Avatar
255 BP, which is about 327 US shipped at Advanced Factors website , new Denso unit.
Old Nov 26, 2018 | 12:29 PM
heidenseek's Avatar
Another option to consider is finding someone local to rebuild. I just went that route with my alternator, although the place I went couldn't find one of the parts and ended up getting me a reman from one of their suppliers.
bballjames
Sep 25, 2020 10:20 AM
ZMonet
May 30, 2018 09:49 PM
cybercop
Nov 2, 2017 12:07 AM
ldaddy
Oct 29, 2016 11:29 AM
DiscoIIBrandon
Mar 14, 2012 07:26 PM
