New Gap Tool Owner! Question.
Old May 9, 2020 | 09:57 AM
Matthew Lord's Avatar
Default New Gap Tool Owner! Question.
Ok, I bit the bullet and bought the Gap Tool. It's pretty sweet and I'm learning how to use it effectively. Sorry to all of you because this means I'm going to be on here asking questions...
My main issue lie in my EAS, which I'm going to start fussing with soon, going to do a compressor rebuild first and then dive in.
First question though is a tire pressure related one. I have all of my tires properly inflated but I continuously get a tire pressure warning on the instrument cluster. It is intermittent. On for a few seconds every couple minutes. I really thought that this would read as a fault and I could track down what was going on and what TPS might be bad. However, I'm getting no faults. Anyone have some insight into that for me? Cheers,
Old May 9, 2020 | 10:14 AM
Blackngold77's Avatar
If you don't care about actually having legitimate TPMS warnings, you can just disable the entire system with the gap tool. Its what I did because I personally saw no need for the warnings or paying extra for TPMS sensors.
I want to say it's under car config -- body control
Basically I just changed the "tpms fitted" from yes to no. No more warnings and no issues.
Old May 9, 2020 | 10:38 PM
DakotaTravler's Avatar
I travel too much to disable TPMS, for now at least since I may go aftermarket. But the issue you describe is probably a TPMS module fault. The modules fail and cause what you describe.
Old May 10, 2020 | 09:46 AM
Thanks guys. I disabled the TPMS for now. I guess I don't really need it. Thinking this through it must be the module. If it was a bad sensor I think i'd be getting a fault.
Old May 10, 2020 | 10:05 AM
wheeler's Avatar
Not sure if the spare tire could be fitted with TPMS? The occasional pressure alerts I have experienced in the last six years have always cleared after adding a couple pounds of pressure and driving a few miles.
Old May 10, 2020 | 10:51 AM
^ Not sure what you mean, vehicles equip with TPMS have a sensor in the spare and a pick-up. Annoyingly if the spare is out of spec it will indicate on the dash that the spare is the issue but all the other tires just say to "check pressure of all tyres".
rh32
Mar 8, 2020 02:47 PM
djkronik57
Nov 13, 2017 04:55 PM
spannermonkey
Sep 24, 2017 07:58 AM
djkronik57
Apr 12, 2016 04:35 PM
Oasisplayer311
Aug 12, 2015 10:43 PM
