New to Land Rovers and the one I have wont move
Old Dec 2, 2018 | 04:39 PM
  #41
houm_wa's Avatar
Default Hard reset
Maybe try connecting the battery cables together for 10-15 min, then connect the battery, start it up, and while it's happy shift from Lo to Hi.
Old Dec 3, 2018 | 06:00 PM
  #42
livfreely's Avatar
Default Hard Reset
Fault shown once I cleared the faults
Faults shown upon startup
Well I tried the hard reset and it will not allow me to switch out of low. It acts like it is trying, and the Hi light blinks but it goes right back into Lo.
here are some of the faults for the transmission upon startup. Also, once I cleared the faults I received one new one in the transfer case.
My display on my LR3’s instrument panel also said “slow down, transmission too hot”.
Old Dec 3, 2018 | 07:51 PM
  #43
your in neutral when shifting the transfer case correct
Old Dec 3, 2018 | 07:56 PM
  #44
livfreely's Avatar
I put the truck in neutral and put my foot on the brake. I then held the toggle switch to the hi position. It sounded like it was searching/going into the hi position, but would return again to the low position.
Old Dec 3, 2018 | 08:09 PM
  #45
I figured you were doing it right just had to check.
With the sound and the faults listed I get the feeling you are going to have to open the transfer case
Old Dec 3, 2018 | 08:33 PM
  #46
livfreely's Avatar
I was hoping I was doing it right .
My Brother In Law is coming to town next month. He is back in the states for a little while from doing some work in Uganda. He has a 1970 series Land Rover over there. He is very mechanically inclined, and I will wait until he gets here to open up the transfer case.
Thanks again for all the help. This LR3 will ride again
In the meantime I will try and do some more preparatory work. I already changed out the rear tailgate hatch door lift struts. I also have the splicing parts to fix the passenger side sun roof drain tube.
rlrigsby
Aug 7, 2019 08:17 AM
mb13894
Jan 1, 2012 06:47 PM
blondebunny
Jan 28, 2011 03:58 PM
donaldaltom
May 23, 2010 04:28 AM
