Bonnet open..beep beep all night..
Old Sep 10, 2018 | 09:43 AM
Athana's Avatar
Default Bonnet open..beep beep all night..
Hi..Bonnet open indicator on dashboard..but Bonnet is shut and alarm going on at night .What can it most likely be.
Many thanks.
Old Sep 10, 2018 | 10:38 AM
abran's Avatar
Passenger side bonnet latch has a sensor. Replace entire assembly or disconnect wire connector and jump both wires with a paper clip or the like.
Old Sep 10, 2018 | 12:34 PM
houm_wa's Avatar
related question....is there any way to adjust the bonnet latch/sensor? I have to SLAM my bonnet down in order to not get the "BONNET OPEN" message.
Old Sep 10, 2018 | 05:00 PM
DakotaTravler's Avatar
You can take it apart, clean it and bend the metal 'spring' that works the sensor. The sensor is just a switch, not unlike the one found inside a mouse clicker for a computer. A metal
'spring' inside pushes down on the switch when closed. The spring is designed to allow tolerance for play. If its been compressed down too far from age/fatigue, it will not have enough force to push the actual switch mechanism. So if you bend it open more, it will apply more force.
I simply cut my wires and tied em together.
Old Sep 13, 2018 | 01:34 PM
BenSchneider's Avatar
6th Gear
Just piling on. I had intermittent alarm and 6 months ago cut the wires to the hood sensor and connected the together. Not a peep since.
Old Sep 18, 2018 | 08:21 PM
spannermonkey's Avatar
I also tied the wires together, but if you are having to slam the bonnet to close it, you may wish to check your release handle is in the closed position. I kept finding my bonnet would not latch unless I slammed it also - only to find out I had a slightly sticky release level. No I just make sure I push it back every time I pull it to open the bonnet.
Old Sep 19, 2018 | 06:12 AM
Athana's Avatar
Thanks..I still haven't solved it so will look over latch if we ever have another dry day here.I slammed it and beeps no more at night but indicator still comes on as " Bonnet open"
Old Sep 19, 2018 | 07:41 AM
Blackngold77's Avatar
give the 2 latches a good dose of WD-40. They can get sticky and not always close
I had the same issue for a while, eventually bit the bullet and got 2 new latches and a new cable (front half only). figured the ~$75 was worth it. swap took 10 min
Old Sep 19, 2018 | 11:50 AM
Athana's Avatar
Hi..where would you buy them.. without going to dealer and still getting oem?
This is different from the sensor yes? Thanks
Old Sep 19, 2018 | 12:01 PM
correct.
The part number is LR065340G (even though it says "right", both are the same part). This part does come with a new alarm sensor as well (and since you'd buy 2, you have a spare sensor on hand going forward). I use Atlantic British when possible.
The cable part # is FSE500031. Most LR parts sites have it, runs ~$20.
I'd do the latches 1st and see if that solves it. Then do the cable another time
archaeology_student
May 17, 2019 04:37 PM
Tercan
Jun 20, 2017 08:43 PM
Jbento2
Jul 13, 2016 08:33 AM
mirepoixmatt
Dec 2, 2012 02:45 PM
Jeff g
Oct 25, 2009 11:15 AM
