not shifting properly
Old Jan 22, 2014 | 08:57 PM
LR Techniker's Avatar
Double check and triple check that ALL your tires are the correct size and if you replace tires in pairs instead of all four at once, shame on you. If the problem started after a tire was replaced or had tires rotated, don't assume they are all correct, physically read the tire size on each tire and compare to Tire Placard on the door jamb.
Small variances in the tires will cause this.
Also keep in mind that tires should be matched. Its a proven fact that two different brands of the same size can have different rolling diameters.
Old Feb 6, 2014 | 10:07 AM
jafir's Avatar
So I had an issue where I updated the software on my TCCM, and the tool I used at the time didn't have a TCCM calibration routine. While driving around with a TCCM error, the transmission would not shift gears properly, even though the TCM wasn't storing any codes, only the TCCM had codes. It would hang out in gears for a long time, and not want to shift past maybe third without going past 4500 rpm. I could shift it manually without issues.
Today I calibrated the TCCM, and all of the issues went away.
Old Feb 6, 2014 | 09:38 PM
houm_wa's Avatar
Jafir, which device do you have to calibrate the TCCM?
Old Feb 6, 2014 | 09:44 PM
jafir's Avatar
Nanocom is what I've got.
But I do want to say that I had an error logged for not being calibrated. This was actually due to me updating the software and the update cleared the calibration.
The only reason I mentioned this is that I've heard of the TCCM going bad, either from water or battery acid, and I was just wondering if maybe a bad one, but one that didn't log any errors might cause similar transmission shifting problems.
Old Feb 6, 2014 | 09:45 PM
jafir's Avatar
One additional symptom mine had is that it wouldn't go into sport mode. When I'd pull the shifter to the left, it would immediately go into command shift or whatever it's called.
Old Feb 6, 2014 | 11:32 PM
houm_wa's Avatar
Thanks; I'll have to look and see if the IIDTool can do that!
buick215
Dec 21, 2014 01:33 PM
nlyell
Feb 15, 2013 01:06 AM
rebelman
Sep 7, 2010 08:08 AM
lipadj46
Jul 18, 2009 01:43 PM
Rangie4surf
Feb 26, 2006 05:25 PM
