OBDII scanner
Old Dec 5, 2012 | 04:46 PM
Eniam17's Avatar
Default OBDII scanner
anyone tried an autel MS300 OBDII code reader on an LR3? I'm not having any luck and all I can get is a Link Error message. I know it's a cheap one but figured i'd see if anyone has a workaround. Thank you
Old Dec 5, 2012 | 05:44 PM
stmcknig's Avatar
I think unless it supports canbus you're out of luck.
Old Dec 5, 2012 | 06:35 PM
Eniam17's Avatar
thanks for the quick reply. I figured it wouldn't work but wanted to check. Any idea of a decent one that does work? Not looking to do anything fancy, just look at basic error codes if and when something goes wrong.
Old Dec 13, 2012 | 09:58 AM
LR Techniker's Avatar
I don't have any specific examples, but as your shopping, make sure you are looking at ones that supports CAN networks.
Also keep in mind that OBDII only covers Engine and Transmission and data display is limited to the mandated parameters, so diagnostics are limited and any other subsystem such as Air Suspension is out of the question.
Old Dec 14, 2012 | 10:26 AM
Eniam17's Avatar
That's a good point. Ideally, I'd like a tool that would allow for some basic resets if necessary (out in the woods on a camping trip, being able to clear an erroneous suspension fault, etc.) I know nothing about this, does anyone know if such a tool exists that doesn't cost thousands and thousands of dollars, and if so, a good brand? Thanks
Old Dec 14, 2012 | 11:57 AM
stmcknig's Avatar
Trying to appear impartial here, do a search for (in no particular order) - Faultmate or IID and decide which meets your cost/benefit curve.
Old Dec 14, 2012 | 05:32 PM
Eniam17's Avatar
Will do, thanks. Feel free to be partial if you have experience or knowledge with any of these. I have neither.
Soccer Dad
Jun 10, 2010 09:57 PM
leadfoot
Sep 14, 2009 05:00 PM
raptorial
Feb 2, 2009 09:09 PM
Rich 00 DISCO
Dec 29, 2008 03:25 PM
Elhoff
Oct 31, 2006 10:38 AM
