Oil change & BG EPR
Old Oct 23, 2016 | 11:25 PM
DavC's Avatar
Originally Posted by houm_wa
Here is my horror story: dealer service department told me my threads were getting stripped out (aluminum pan and steel plug). So to avoid installing a new pan ($1800 part) I revised the oil plug using some stainless steel pipe fittings. $10 solution to a $4000 problem.
NICE. This is my thought process.
update for everyone else. Just finished a 600+ mile trip to Pismo this weekend, car was very happy, this EPR stuff seems to do OK. I may try it on an older car with sludge.
Old Nov 3, 2016 | 08:30 PM
roverguy7's Avatar
EPR is good stuff, on this engine I use 2 cans(one can per gallon of oil is ideal) I also always waste 5-6 qts of oil following the service to flush out the chemical, letting it run and rinse out the passages/components.
EPR is not really designed so much for cleaning out sludge or flushing stuff out(use BG120 for that, and be sure to have a few extra filters on hand if there's much build up). It's really designed to break up carbon that can be riding on the piston rings, not allowing them to properly seal, restoring some lost performance, or keeping from losing it in the first place. I will usually bump the idle and let it run for a good 45 minutes or so with the chemical in there, with a few throttle sweeps along the way. This stuff is pretty volatile, so you don't really want to leave it in there and drive.
DavidG
Dec 9, 2016 03:34 PM
iconoclast
Jul 13, 2016 08:04 AM
collin Barrows
Aug 28, 2011 07:13 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
mwindth
Dec 21, 2010 08:28 AM
