Oil loss won't start help
Old May 16, 2023 | 04:26 AM
Ericmunoz's Avatar
Default Oil loss won't start help
So I got a 2012 hse when my dad passed 1st issues I have to bleed the air out of coolant every use I top it off bleed air but can't find cause
2ed no dip or leaks found on oil but have to top it off been on it and was running fine no smoke ECT but after it over heated it didn't wana go agin checked And top off all fluid evw. Added some Lucas to the oil it was running smoothly then one day I did my normal top off before leaving bleed the air out more oil in checked the level and not 15 mins later it died coming up the off ramp no warning lights Nathan I got a lil white smoke right before but engine sound fine was vary watchful for any abnormal but it just died and has not started again cranks fine but won't turn over the most I had was a yellow engine light that only came on after my spare tire pressure triggered this car is very sentimental to me and I'm wondering what am I gana have to do to fix this I don't think I blew the motor as there's not clicking or any stranger nose when I try And turn it over no oil in coolant and oil is clean all normal coloring and smell I know the sound of bad valves lifters and ECT and know what to listen for but I'm at a loss here it's a hse v 8 please help
Old May 16, 2023 | 11:30 AM
houm_wa's Avatar
If it's a 2012, it's an LR4, and you may get more responses in the LR4 forum. Best of luck to you. I hope my kids are as sentimental about my LR3 (which will surely out-live me) when I'm gone.
twaszak
Jul 19, 2022 05:43 AM
TriggerPuller
Mar 28, 2018 10:49 AM
SeasideRHT
Nov 3, 2011 09:49 AM
discoandaboat
Oct 3, 2008 09:21 AM
wadematt
Jun 12, 2008 09:30 AM
