Outside Temperature
Old 08-23-2015 | 05:46 PM
uoflcardfan77's Avatar
Default Outside Temperature
It got down to 59 yesterday. When I got in the LR today it was about 83. The dash readout still said 59. The A/C worked fine.
Does this sensor have any connection to the A/C & heater, i.e. if it is not working will it affect whether the A/C or the heater works?
Anybody have this problem and if so how do you fix it?
If it's not connected to the A/C or heater it's no big deal but the geek in me would still like to know how hot or cold it is outside.
Old 08-23-2015 | 07:04 PM
Joemamma1954's Avatar
The temp sensor is usually found right behind the grill, in front of the air conditioner condenser. From what I understand, it has nothing to do with your A/C or heater, just telling you what the ambient temp is.
Old 08-23-2015 | 10:10 PM
EstorilM's Avatar
I wrote something about this the other day because my AC had been cycling annoyingly sometimes when i first started the vehicle on hot days, as if it were encountering a pressure drop / freeze up of evaporator and had to pause for a second.. but I seriously doubted that.
Never looked much more into it, but one day the same thing happened to me - when i got to work it was unusually cool out and when i started it a few hours later the sensor didn't update yet, and still refused to in stop-go traffic. With the cooler temp readings the system never cycled - so I would say it's somehow related to how it interprets pressures and temperatures elsewhere in the HVAC system.
Either way though, it's not actually a problem (I don't think) with the temp sensor. The vehicle is programmed to only update the temperature readout with the sensor data if you're traveling above a certain speed, and even then it will "smooth" the data and only provide updates periodically (I'd say max every 60 seconds, again only if you're at a fast enough speed for it to use new data).
Most modern vehicles work this way - but the ones that don't will always show you some crazy weird numbers sometimes (ie. 110 if you're in traffic on a 90 degree day) etc.
Old 08-23-2015 | 11:49 PM
pgoodrich's Avatar
As mentioned above it should update after driving. But it does affect the A/C operation along with many other sensors in the LR3. If it doesn't change after driving it needs to be replaced, when they go bad it usually reads cold.
Old 08-24-2015 | 04:04 PM
Here are the two parts I can find. I'm wondering which one is what I need to order. My guess is it's probably the more expensive one.
http://shop.advanceautoparts.com/wcs...3_pri_thmb.jpg
http://shop.advanceautoparts.com/wcs...0_pri_thmb.jpg
Old 08-25-2015 | 09:39 AM
pgoodrich's Avatar
The second link is the ambient temperature sensor which is what usually goes out.
Old 08-25-2015 | 01:21 PM
Thank you. When I drove it yesterday it started out at 59 and slowly crept up to 68 . . . but the outside temp was 78, so it looks like it's working (sort of) but is probably on it's way out. Can't believe it's the less expensive item that I need to get.
Old 08-25-2015 | 03:09 PM
And of course no one has that particular part in stock or has any idea when it will be stocked. ARRGH!
hotelmez
07-09-2008 12:10 PM
rkrainak
10-11-2007 09:15 PM
smithwick
02-27-2007 01:53 PM
Quick Reply: Outside Temperature
