P0173 Code
Old Jul 25, 2019 | 05:59 AM
sickws6's Avatar
Default P0173 Code
Running fine, no misfiring, normal fuel consumption. Any suggestions what to look for causing this code?
Old Jul 26, 2019 | 09:39 AM
sickws6's Avatar
Anything? MAF?
Old Jul 26, 2019 | 07:56 PM
DakotaTravler's Avatar
When were the upstream O2 sensors replaced?
Old Jul 27, 2019 | 06:37 AM
sickws6's Avatar
I have no clue but not getting any 02 sensor faults.
Old Jul 27, 2019 | 06:58 AM
You are not getting a MAF code either, yet you suggested it. Point is faulty things don’t necessarily generate codes. And when it’s specific to one bank, it’s usually a component specific to that side. A bad MAF would likely cause fault codes for both banks.
Old Jul 27, 2019 | 10:10 AM
sickws6's Avatar
Ok anyone tell me what's up with this. Looks like ranges are way extreme on short
Old Sep 13, 2019 | 07:25 AM
sickws6's Avatar
Changed MAF, changed PVC. New oil filler, found small crack on intake baffle, fixed that. Changed throttle body gasket. No signs of any vacuum leakes or intake. Still getting lean codes both banks now. I'll check fuel pressure next I suppose. Mpg is right on 14-16
Old Sep 13, 2019 | 01:47 PM
abran's Avatar
While running spray brake cleaner/starting fluid around the motor looking for leaks. Oil fill pipe, around injectors, etc.
If no change when spraying, assume MAF(both banks).
If that does not fix it a good BG fuel rail and intake cleaning should.
Old Sep 13, 2019 | 06:27 PM
sickws6's Avatar
BG fuel rail and intake cleaning?
Old Sep 14, 2019 | 03:08 PM
abran's Avatar
